1-After hours of searching and not finding the proper solution, I'm here.
. My Fiat 500 1.2 (60k miles-2015), started to make noise from the rear end, I changed the shock absorber (bushes and the shock, both failed). Now it is still making noise different from before, I've swapped the shock absorber. and springs with each other, but nothing. Could be the axle bushes?? (even though the sound is very different, it is like something hitting up when going over a small or uneven surface)
2- This is not the only problem, the front spring broke so I ordered them, but when I opened it I realised the strut had failed as well. So waiting for all the replacement parts. Should I change the lower control arm? It is still solid but it looks lower than the bushes, how do I know if is it bad? I did alignment a few times but the car is still not going straight, so maybe it's better to change them.
Thanks for any suggestion or solution, the rear-end noise is making me mad. I have more issues, but let's solve these first.
