Technical Fiat 500 1.2 Petrol, jumped a tooth according to the AA man
Reedy123
Hi Everyone
My wife's Fiat 500 died on Friday and went I to limp mode, she called the AA out and the guy said the engine could of possibly jumped a tooth on the timing belt, on there report the scan has shown up with a 9GFP0011 Camshaft 1 and a P0016 Crankshaft Position Sensor, as you can see by the report which I will attach, I was going to attempt the cam belt change this weekend, which I have proceeded to do, I stupidly thought that a 500 would be the same as the Grunde Punto I once had, I took the cambelt off fully expected to see a tooth missing or 2, absolutely nothing, the belt needed changing but every tooth was intact and no broken teeth on Camshaft sprocket or anywhere else, I locked both cam and crank, changed the waterpump, now I am attempting to put a new belt on and I just can't get it on, it so so tight, I'm beginning to wonder if I've done anything wrong, are the 500 belts super tight, any info or help, point in the right direction would be appreciated people
Thank you Reedy
Model
Fiat 500 1.2 Petrol 2015
Year
2015
Jumping a tooth will not mean it's lost a tooth, there are a few dozen teeth engaged. It means it jumped a tooth as in the belt and cam are out by one tooth.
Nearly all modern timing belts feel too tight to go on. The locking kit is a must as there are no timing marks. And you will also have a pile of experts on here telling you that you are doing it wrong.
If in doubt hold the two belts up together.
Thanks m8 for the reply, yeah done that held the 2 belts together same size, it's me then, I aint done a cambelt in a few years, especially on a Fiat, I'll give it another go, I mean it's nearly there, so I'll solider on.
Also forgot to mention, The Mrs also drove for about 1 1/2 miles while the Engine Mgmt light was on and in limp mode til I told her to stop and get it recovered, question is there any tolerances on the 500 or will it need a compression test on the cylinders, shudda done this I the 1st place, I'm an idiot. 🤪🤪🤪😩
Update
Got it all most all back together, pattern parts especially water pump are slightly bigger than original parts, hence how tight the belt was, my m8 came and got it on, started it up and it was on the money, no chuffing and hopefully no valve damage but like I say got to finish it off and run it, thanks for the input people.
