Haha Daniel, I think I would have given up today if it wasn't for reading you post last night. I can't believe it but it actually turned on. Funny story is I spent 2 hours checking the carb, pulled it off completely, check the jets again, checked the points, checked the spark plugs with a multimeter, checked the voltage regulator (found a dodgy wire but no clue as what it's for, hanging on by a thread for now), checked fuel flow, etc.
I cranked it for a good 30 seconds on several occasions, and nothing happened. I have a battery charger that I resorted to 3-4 times today. Eventually I started filming a video so I could post it here to see if while cranking anything stood out to you guys, and it started
I spent about 15 minutes trying to get it to run smoothly, but I'm not sure I've gotten there. In an effort to reduce the sooty sparks I had with the previous carb, I found this guide from weber
https://www.carburetion.com/Weber/adjust.htm, and it helped, but I don't know if there's a better way.
I turned the mixture screw fully closed (clockwise) and it actually sped up the engine and was running fast. So I backed it out, and I went too far because when accelerating the exhaust gasses were slightly dark. So I ended up about a turn or so from closed (turning counterclockwise).
Idle I followed the guide of turning clockwise until it starts to run rough, and then back it out 1/4 to 1/2 turn.
Throttle linkage screw, turned out until generator light starts to appear on the dash.
The problems I'm finding, is when moving the accelerator linkage, the initial acceleration I notice a few hiccups, then it rises smooth. Letting go of the accelerator it goes back down to idle, and sometimes wants to turn off. I also noticed a few spits and pops.
The biggest win is that it actually turned on, and seems to turn on after a half second or so, compared to before when it used to crank for a few seconds with the 28imb. I think I will attempt to adjust valves to see if that improves, but first want to get her going.
Anyway, a little picture dump, maybe someone can spot any issues
(anyone know what the green wire on the left most voltage regulator coil thing would be?it goes into the passenger compartment?)
