General Need Repair Manual with Excellent Illustrations
stevenk9958
Yucca Valley, CA
Can anyone recommend a really good repair manual for my 1978 Fiat 124 Spider Convertible 1800? I need to reassemble a number of parts to my engine like carburetor, radiator, air pump, hoses, wiring harness and a few others I can't identify and need a manual that shows clear photos / illustrations. If possible, please attach a photo of the cover of your manual so I can find it on eBay. Thank you!
Check out the downloads section
Or Haynes (UK) do great teardown manuals if its just the engine you can look for Fiat 131, Lancia Beta on ebay if these were sold in the US. Includes dimensions, torques,tolerances etc
I remember your previous thread ^^ with the same query and you had dismissed both the Haynes and Chilton manuals as not meeting your requirements. I don't recall any 'shop manuals for cars back then (c.1978) having color pics. Even the wiring diagrams were in b/w and used 2 or 3 letter codes to indicate the cable colors.
One possible solution would be for you to post pics of the things you want to reconnect and maybe someone here can advise you. The under hood wiring is relatively simple, the cables often can only reach their intended electrical unit, some units have block connectors that will only allow the correct group of cables in the appropriate mating block to be connected into place on the unit, connecting cables to, e.g. relays, just needs you to look at the terminal numbers on the underside of the relay and using the wiring diagram as your guide, connect the appropriately colored cables to the correct terminals.
Not very difficult, just needs a little patience + might have to clean the colored insulation to correctly identify the color.
Connecting a carb.? It can only be fitted in 2 ways - the right way is so that the fuel supply connection (a short brass stub/little metal pipe) is towards the front of the car. Then connect the flexible fuel hose from the fuel pump (which is on the side of the engine below the intake manifold) to this brass stub. If there are 2 brass stubs on the carb, the larger one is the fuel supply from the pump, the smaller one is a fuel return to the fuel tank and will be connected to a smaller flexible hose. Tighten the hose clamps and connect the throttle linkage and small coolant hose connections to the choke (afaik, your carb has a coolant operated choke).
Radiator? It fits into a bottom rubber lined bottom mounting bracket, then is secured in place with 2 washers +nuts, connect the top and bottom coolant hoses, the pipe to the expansion tank and connect up the electric cooling fan wiring and the fan sensor wiring (at the bottom of the radiator). After any other hoses have been connected (incl. at the carb. choke unit) and heater unit, fill the cooling system with coolant, run engine and bleed any air from the system.
Air pump? Haven't a clue, (over here) I've only seen cars after the air pumps had been removed and discarded along with the rest of the emissions gear.
Afaik, many in the USA remove this 'smog' equipment and blank off any openings to improve engine running, but as you're in CA, idk if this is ok to do.
Posting pics (in color if you prefer...) of the areas you're working on and the units/parts you want to re-install might be the best way of getting the help you want.
Thanks for the help. I did end up buying the Haynes Manual new from Amazon. I'm taking your suggestion and posting pictures here of things I don't know about.
- Air Pump: Anyone know what this does? Does anyone know if I need it here in California? Facing the engine compartment from the front bumper looking in on the left side down low there looks like a bracket that will hold this in place and there is a V-belt that connects this to the engine and a single hose, anyone know where the other end of the hose goes?
- Gasoline Vapor Filter: that's what it says on the bottom. Any idea where this goes and what it connects to?
- Unidentified A: What is this and where does it go?
- Unidentified B: What is this and where does it go?
B looks like the exhaust heat shield that bolts to the cast manifold
The air pump is part of the emissions control system for exhaust tailpipe emissions
The carbon can is part of the emissions control for evapourative emissions
You will need to get advice from US owners as these systems were either not fitted or removed from European cars
