1 Year off the road, but on the mend...
Happy Christmas everyone, hope you all had a good one!
Did a bit of tinkering on the day after boxing day (once the hangover had worn off) to sort out this intermittent problem with the rear nearside brakelight.
the bulb is fine, but either the wiring or the cluster has been causing the light not to work, until you unbolt the cluster then it works fine!
Anyway gave all the contacts a going over with some light sandpaper, reinstalled and it seems to have done the trick.
(I've always found the individual wires a bugger to remove from the plastic clip haha)
also see handy brakelight testing solution when no family members can be bothered to help:
(please ignore sister's horrible Micra in the background
Also changed the rear licence plate bulbs out for new LED's, the old LED's were cheap and no longer working, no photos though.
While I was working on all this, I had the Punto's engine running to get nicely up to temperature and simulate a long(ish) drive. This was mainly because I had started it that morning to charge the battery, and noticed brown water sputtering lightly out of the exhaust, and a fair bit of white steam when revved. I checked the oil filler cap I found the dreaded Mayonnaise after cleaning it only the other day after having the engine running for about 10 mins. This got me worried that there was coolant leaking through the head gasket even though I had just changed it!
A quick bit of Googling in panic put my mind at ease a bit; the car hadn't been fully up to temperature since the gasket was changed, and the oil hasn't been changed since either, so these symptoms might be expected. The amount of condensation/residue in the exhaust system was probably substantial, so I'm hoping if I start the Punto up again at the weekend it won't be so bad now it's had a good(ish) run.
That's it for now anyway, any suggestions/advice on the matter would be appreciated
