This is weird, because I have a 2000 diesel and the clutch pedal is connected to the engine by a cable. The plastic bit at the end of the pedal broke last week (after 260,000km), the replacement plastic bit and new cable cost about 90 GBP. The 'mechanic' that fitted it, however, forgot to tighten up the cable and didn't put an extra nut on it (at the engine end) so it became impossible to change gear. Looked at it myself and I adjusted perfectly with an ordinary spanner (10mm - put a second nut on it just to make sure). I'm in the dark here - I'm just a violinist and have little or no idea if I've done the right thing
