General multijet 130 water ingress
Re: WATER INGRESS - NEW FIAT/PEUGEOT etc
Appears a recall will be issued in october?
http://www.ukmotorhomes.net/fiat-water-ingress.shtml
We have heard reports, from some owners, of a problem with new Fiat Ducato/Peugeot Boxer based motorhomes where water leaks through at the centre of the plastic tray at the bottom of the windscreen. The tray is in two halves and it seems that the seal is ineffective. The water leaks into the engine bay and collects around the injectors causing corrosion.
One owner has told us that, after contacting Fiat Customer Services, they were told that in mid October Fiat will recall the Ducato Camper owners that reported the problem and fit their modification kits.
Leaks into the engine bay of New Style Fiat Ducato/Peugeot/Citroen
The problem is water leaking into the engine bay and soaking various components in the engine bay.The long term effects of this will cause numerous and varied problems for these vehicles in the future.It’s all very well and proper to take the matter up with Fiat but in the mean time you vehicle and investment is being ruined.
There are several design faults not rectified by one fix:
1 Water runs behind the plastic scuttle below the windscreen and via the joint of the two halves.
2 The extreme ends of the plastic scuttle are lower than the drained channel with no means of connecting with the off centre drain tube so they fill and flood into the engine bay.(exasperated if the vehicle is parked on a camber)
3 The fresh air intake drain tube is to the rear of the intake so if the vehicle is parked nose down the water leaks via the seal between the two halves of the intake.
4.Water runs between the plastic trim plates above and down the side of the headlamp
5.The gap between windscreen and a post acts as a channel to funnel water under the bonnet.
6 The gap between bonnet and headlamp has no means of stopping water entering the engine compartment
My suggestion for a solution to the problem I have done this to my Burstner Solano and it works after testing with a hose no significant sign of water.
1.Seal the plastic scuttle to the windscreen
2. Fit drain tubes to the two low areas of the plastic scuttle (i.e. both ends)
3.Fit a drain to the fore end of the fresh air intake
4.Seal with silicon
5.Seal with silicon
6.Stick foam to underside of the bonnet short edges to form a seal.
For the 3 drain tubes I used 18mm dia metal inserts used for plastic pipework its easy to drill the necessary holes an 18mm wood bit is ideal for plastic.I then sealed the inserts which have a small lip with silicon.
To the inserts I attached 25mm dia plastic flexible conduit its a slack fit on the 18mm insert but easily taken up with silicon.The plastic conduit is ideal for the task as it can be tied back into almost any shape I used cable ties to secure the pipes with them terminating level with the bottom of the main plastic bumper.
To seal the plastic scuttle its easier to remove the bonnet 4 bolts mark with felt tip pen the heads of the bolts this will allow exact repositioning.Remove the wipers 2 nuts.Remove the trim panels above headlights 2 machine screws each plus clips.
Then release the plastic scuttle some screws and clips no need to remove completely just pull back to make the application of the silicon to the inside face easier.Refit the scuttle it may be necessary to hold the scuttle to the windscreen with some small wedges from the wipers.Any excess silicon exuding can be trimmed with a sharp knife after setting.
When drilling the hole in the freshair intake drill it on to the drop lip so it’s in the lowest possible position.
Using evostick ( if your foam is not self adhesive)stick 5/6 mm thick close cell foam strip to the underside of the short edges of the bonnet,foam about 15mm wide.
Sealing the area around the headlamps and body use black silicon since there is a groove for the most part its easy to make a neat job looking like it’s meant to be
I am aware that these in therory could affect you warentee but I doubt a dealer would take such a line.
The parts used can be obtained from any DIT store I got mine from Leroy Merlins in Malaga
What a task on a new vehicle that cost £45k but it will definitely be worth it.
Colin Frier [email protected] ( Malaga Spain)
Any problems e mail me.
Hi new to site,
joined after seen u tube video of water ingress on fiat m/homes.
It was raining so I thought I would check our new m/home, and sure enough rain was pouring in all over the engine.
So temp fix Duct tape ( to the rescue ) Phoned dealer Still no official fix available but he is an excellant dealer and says if fiat does not carry out fix he will at his cost.
He has allready done two and no more leaks.
So thanks to the member that posted the problem.
Andrew
There IS a fix (I mentioned this in the post above yours #23),I have done loads already.The recall comes in 4 parts,you will be notified when to bring your vehicle in in due course (give dealer chance to get parts in) but you will need to leave it for around 4 hours(y)
Is this the full VOSA recall fix I have seen mentioned on another forum???? Apparently recall is for a lot more than just the water it seems to also include steering rack and a whole lot more. Can you shed any light on this???
Yes of course but remember;
Affected vehicles must fall between the determined chassis ranges and many of the recalls are limited to engine type/sizes so not all recalls will affect all vehicles.
steering rack - lubrication
injectors - software update
wiper motor/starter/abs - cover
injectors - corrosion inhibitor/protection
gearbox - check (3.0 engine only)
pipe - check location in clip
I'll post up more details during the week:)
Garages would appreciate it if you could wait till you recieve recall letter as 15 ducato vans & 8 motorhomes desending on a small garage on a monday morning dont bare thinking about parking wise:(
Thank you most greatful for this and for the offer to post details during the week. Will be back in the week to have a look (y)
Re: Engine bay water ingress
Has anyone had the full repair done on their vans and did it stop the water getting in.
I keep reading what fiat have said and them having a customer hotline but nothing seems to happen.
I have also been given its going to be done then the dealer does not have all the parts and had an e-mail today saying fiat will no longer do any scuttle repairs as what they do does not work.
Just to say I have had the full 'fix' on my motorhome.
It has apparently worked.
The mechanic had difficulty getting the mastic to stick the scuttle satisfactorily & had to repeat it several times.
Also, where the two sides meet in the middle, after applying the mastic, he found it necessary to use a screw to hold it all together.
But, all in all, it seems to have cured the leak.
The Dealer said return it if any leak reoccurred.
Rgds,
Jodiedog
Hi
How much faith do you have in Fiat's so called fix if they got it so wrong the first time don't trust them the second time.
The problem is not just the scuttel :
The well at the end of the scuttel hold water they have small drain holes that become blocked if they are not then water falls onto the fuse/relay box,
The fresh air vent takes in water and if parked nose down it will fall on the engine after it leaks via the joinoing seal,
It leaks down the sides of the bonnet and the sides of the headlamp.
Depending how you are parked the problem changes from bad to very bad.
See my earlier post I have cured mine after a very good soak from a hose no leaks be a good idea if Fiat read it as well.
Rumour on other sites is that Fiat have withdrawn their fix as is does not work what a suprise!!!!!!!!!!!!!!!!
Colin Frier
Can anyone give the part number for the engine cover for the 2.2 engine and also what is the price to buy this item? Fiat or peugeot part number and if its a reply from a dealer availability of cover.
The thing is with the scuttle bodge ( and it is a bodge ) is that should we get any problems where the windscreen needs replacing,it is going to be one hell of a job to get the screen out especially as it`s stuck to the scuttle after the bodge.Who is going to pick up the bill for scuttle removal,screen replacement and re-sealing scuttle every time a screen cracks or chips:rolleyes: Us mugs I suppose.
I just hope they have a more permanent solution in the pipeline,but I doubt it somehow.
steve
I have just purchased a new Fiat ducato XLWB 3L on the 21/11/07 traveled 600km’s so far, which has the same problem, water leaking onto my injectors and corrosion over the rocker cover and injectors. By the way I’m in Sydney Australia and I just today 23/11/07 taken it to a fiat service center in Arndell park Western Sydney trucks, and they where quickly to say it was probably because I leaved near the ocean, I laughed I said in 2 days of owning it LOL. Any I don’t live near the ocean more like at least 40km’s away. Anyway she took photos and said she will email fiat Australia and take it from there. She also said that If I decided to go ahead with repairs and they find out that its not a manufactures fault I would liable for the incurred costs lol. I then called fiat Australia and spoke to a person by the name of Tim and he was quickly ready to have answers in there favour, explained that the ducato’s leaving the factory are 100% tested and do not show this problem they are also inspected upon arrival off the ship for damage so any vehicle with damage is noted, so he also went to say that it could of happed at the dealer or in transit from Italy to Sydney , he also went to say that warranty does not cover corrosion on the engine only the body. My stomach was becoming sicker and sicker, also went on to say don’t thing about it being a Friday just enjoy my weekend. Which made me even sicker. Im so disgusted. Will keep you guys informed of the outcome.
Hi Naser Thats what we get in the UK,mines a Peugeot,to date I have looked at all these Seval vans Fiat/Peugeot and Citroen all have water ingress some of these are still on motorhome dealer sites awaiting for the first new owners.
last week I was told by peugeot they would not be fiitting an engine cover that is now being fitted on all new vans built.
have a look here
on motorhomefacts
That will take you some time to read.
Your dealer and fiat downunder are taking the mick stand uptp them some of use here are,its a battle.
I have also read its a problem in mainland Europe its also been taked about in motorhome mags.
Engine cover
Re the water ingress problem on Boxer 111,has anyone a part number for the 2.2 L cover and a picture or diagrame if poss?
Are they now available to buy and whats the price?
Hi
can anybody give me an e mail address to Fiat Italy I have a 2007 130 multijet Burstner Solano Motorhome which I bought new in Germany in August
but I live in Spain so would like to advise them of my address so I can have the various recall work carried out on my vehicle ( not water ingress Iv'e fixed that myself)
As for the engine cover waste of time the water comes in in several places not just the scuttel first principal KEEP WATER OUT OF THE ENGINE BAY it's not an amphibian.
Colin Frier
