Punto (Mk2/2b) Mk2 Sporting Turbo
New pics
interior gauges
Power graph:
CAR SPECIFICATIONS:
- Model : Sporting
– Engine size :1242 16v
- Year : 2002 "52"
– Colour : Sprint blue
ENGINE MODIFICATIONS :
- Munkul-spec turbo conversion
- Munkul-spec tubular manifold
- Garrett GT1549 turbocharger
- Front mounted intercooler
- Ferriday 1.2mm decompression plate
- Greddy REBIC IV fuelling management
- MR2 FCD
- Modified inlet manifold with 8 injectors
- SFS green boost and intake pipes
- Supersprint backbox, custom munkulbodge downpipe and centre section
- Magnecor KV85 HT leads
- CG Motorsport 3-paddle cerametallic clutch
- Sump modified for oil return
- Alloy/stainless oil catch tank with stainless braided lines
- Stainless relocation bracket for brake fluid reservoir
- Carbon Fibre battery cover
- Lots of stuff i cant remember
STYLING MODIFICATIONS:
- Full Abarth bodykit
- Colourcoded mirrors
- Black/silvatec side repeaters
- Mk2b rear lights
- Detangoed headlights
- Debadged boot and bonnet
- Short ariel
INTERIOR:
- Abarth mats
- Abarth steering wheel
- Gtech-pro model SS
- AEM wideband AFR gauge
- Autogauge boost and oil temp gauges
- Carbon surround
CHASSIS:
- FK highsport coilovers
- OMP alloy strut brace
- Bendix GT front calipers with Red Dot XE Fast Road pads
- HGT rear beam conversion with HGT discs, calipers, stock pads
- Balance Motorsport carbon braided hoses all round
- Munkul-spec superflex polyurathane rear bushes
- Munkul-Spec top and bottom engine mounts reinforced with polyurathene
- Sporting 15" alloys refurbished and powdercoated in anthracite, Toyo T1-R all round
Drop of 60mm front 35mm back
Front camber: -1.8 degree +/-0.1, Toe in 0.8 degree
ICE:
- Pioneer HU
- Infinity Reference components
- Infinity Reference 6x9s
FUTURE MODS:
- Polyurathane front wishbone bushes
- Greddy FCD
- Mocal 13 row oil cooler (just to fit when i get time, before summer comes)
- Possibly up the boost, stainless exhaust, depends
- Sell it
cheers people :)
Shakey - cheers, remember, you were the one who helped me with a load of stuff when this project was still in the theoretical stage (y)
Theres no way i would remove the abarth kit :confused: whats the point in making a car look worse?
Well today i fitted my BOV
Went for a quick drive, found out that connecting it to the same vacuum line as the boost gauge was not a good idea - threw the gauge reading way out! I knew better, but i was lazy.
So connected it up to the breather vacuum instead, and blanked off the crankcase-manifold pipe.
Went for another drive, found out that it didn't open, tweaked the adjustment screw a load but it did nothing.
It then developed a misfire. Bummer. Fixed the misfire by gluing some silicon pipe over a split in a HT lead boot.
Dismantled the BOV, found nothing wrong with it. Reassembled it with sealant on the diaphragm just in case it was that.
Wired in the Greddy FCD.
Started up, ran lean as feck. Tested the voltages it was putting out and it had gone totally haywire - putting out 12v on the 5v wire, WTF! Opened up the casing and played with the components on the circuit board. Put it back together and it tested fine. Plugged it back in and the engine ran just fine after that.
We tweaked the map again to compensate for the loss of fuelling (the stock ecu now thinks there is only 1bar of pressure instead of the 1.18bar that it thought there was before, so injects less fuel, something that i dont think many FCD users remember). Now the map sensor fault doesnt come on when cruising above 3000rpm, so it seems to be doing the job it is supposed to :top: as long as it doesnt go haywire again, then i think that this completes the turbo conversion fully :)
The BOV still doesnt open, though. Kinda stumped as to what it is - unless the breather vacuum doesnt flow enough pressure... will find out soon enough when i look at the spare manifold on monday.
i know... the breather pipe i mean is the one coming off the manifold, i thought it was rather pointless leaving it o the crankcase breather since it vents to atmosphere anyways :) i think the BOV is knackered now though.
Its an OMP alloy brace. I didnt buy it new, but strutbracer.com or ebay will offer plenty of choice for braces for the correct engine in a mk2.
Well things havent moved much with the car.
After a few days, the FCD fried itself along with the MAP sensor - guess it was halfway to being knckered after all. But i dont think a new one would sort it anyways. Im just running it without a FCD at the moment.
The BOV turned out to be knackered so a new genuine SSQV was bought - but the 1.2 doesnt SEEM to generate enough vacuum to operate it anyways. So far i havent been bothered to change the spring for a light one but it hopefully will sort it.
Ive decided the only way forward with the car is to install standalone management, and run a single set of larger injectors. This gives me way more potential for future upgrades - if i pull this off then i might go crazy with cams etc....:eek:
Firstly i needed a different inlet manifold - the Mk1 manifold will allow me to run a cable throttle instead of the fly-by-wire that the standard management uses. I also can use the larger 48mm 1.6 throttle body.
Hardware bought and stripped:
stripped down to the injectors which were being a pain, so i left them in for the time being
Compared to the mk2 TB - marea TB is 48mm, Mk2 TB is 43mm. Marea one also has the idle control valve and stepper motor built in, which is getting junked.
Full Megasquirt MS-II management system has been ordered, Im just waiting for it to arrive so i can get on with building the PCB up!
:yeahthat: :)
In the past few days, my desk has went from this:
to a fully working basic MS-2 setup
Then modified with wasted spark and boost control mods
Now running MS-2 Extra firmware and capable of handling a variety of extra options. I have a few more mods still to do, such as knock sensor input and warning LED outputs, but its more or less finished
cheers :)
Today Jordan persuaded me that i had to buy one of his universal Cobra Sport backboxes that he's had for years for £40.
So i did the silly thing: i bought it and spent the rest of the day fitting it.
Mocked up:
No pics of MunkulTech bodgery, but it was kinda thrown together with bits of 2 1/4" pipe bends lying around.
Looks tidy though
And what an improvement over the supersprint! Boosts harder, pulls like an express train, and sounds a bit silly. It pops and bangs like crazy on downshifts :D I estimate its running at least 150bhp now because it feels faster than it did when it was RR'ed at 145bhp, although it now has a sports cat. The boost now peaks at 0.7bar near the limiter, whereas before it only boosted to 0.6bar, thats with no other change!
I dont care for the letterbox tip (who does?) but its a full T316 stainless box with reweldable tips, so when i get a proper stainless system made up from the turbo-back, i can re-use the backbox and have the tip changed at the same time :) the mid-section is still 1 3/4" so it really needs changed as well to make it a full 2 1/4" system.
worlds worst video, doesnt do it justice really
[nomedia="http://www.youtube.com/watch?v=cPWpf2znvcI"]YouTube- New Cobra backbox[/nomedia]
