jjr0305
As the title says, I've found a white/creamy substance on the bottom of the oil filler cap. I can't find any in the actual oil or on the dipstick though. I've also been losing coolant since it got serviced two months ago. The line on the bottle has gone from max to below minimum in that time. Is it ok to just top that up with some distilled water?
I took the car to the garage and the guy did a gas test on the coolant, which came back negative, so he said it's most likely not a head gasket problem. I've got the 1.4 Sport with 60k on the clock.
I've had no overheating, problems with the blowers, or bubbling noises as of yet, so could the two issues be totally unrelated? I've had my HG go on me on my old MK2, so really don't fancy it happening again
