RobMcCoy1701
- Joined
- Feb 3, 2014
- Messages
- 1
- Points
- 0
I'm glad someone has done it as I was hoping to do the same. Will get those can bus models. Not a bad price either.
What about expensive cree version. Anyone tried these leds?
http://www.ebay.co.uk/itm/380-P21-5...arts_Vehicles_CarParts_SM&hash=item3f28c10e7e
These are the ones I've just had fitted and they look great...
http://www.hids-direct.co.uk/canbus-380-p21-5w-27-white-smd-led-error-free-bulbs/
For DRL Led
What about interior LED replacements. Will a pair of these fit and work (42mm)
http://www.auto-lighting.co.uk/prod...Festoon-Bulb-36mm-39mm-42mm-CanBus-WHITE.html
Can please someone confirm 42mm will fit for interior or should I get 39mm? Don`t have the car at hand at the moment and Osram lamp configuration tool suggests 41mm C10W![]()
Have any of you using this type of LED bulbs in DRL lights experienced any problems with them?
http://www.hids-direct.co.uk/canbus-380-p21-5w-27-white-smd-led-bulbs/
Last week I accidentally noticed that one of the led bulb in DRL mode starts with slight blinking after 15 minutes of driving. If I put on the main lights the blinking stops. Also if I am driving with main lights on all the time there is no blinking. The blinking starts only if I am driving in DRL mode all the time. I find this very strange and annoying. I really don`t want to spend another 17 pounds plus shipping for another pair and experience same results in the end.
Do you thing the bulb is defective or is there another problem?
Also another question. I noticed the headlights get quite warm after half an hour of driving? Like 40-50 C. Is this normal with H4 bulbs installed? I inspected the housing very carefully and there is no sign of melting or anything but I still find it strange. Been using cars with H7 bulbs in the past and haven`t noticed this problem but don`t know if this is normal with H4. Thanks.
I just received refund but only for one bulb. So I need to order one or two from another seller. Can you share the link of the store you ordered your pair?
