Could it be done by home DIYer?
I would give you a cautious yes on that. Not because the task is in itself of extreme difficulty but because the consequences of getting it wrong on an interference engine are ruinous. However as our earlier type Panda engines are supposed to be non-interference we should all be OK even if we get it timed up wrong? All that should happen is it won't run!
In the Grande Punto section there is an absolutely excellent guide on how to do it, by Andy Monty, in the Guides section (top left of page) and Charlie (Veresecrazy) has another very worth reading in this Panda section (see Guides).
I had a bit of a stab at describing it when I did Becky's back at the beginning of last summer - to read search back to 09/06/2018 (page 17 at this time) in this Panda section - It's entitled "Becky's timing belt - the ongoing saga". On older simpler engines the manufacturer would cast or machine timing marks into the pulley/sprockets (shall we just call them pulleys?) with corresponding marks on the front of the engine against which these marks were lined up. This made life simple with no special tools required. The pulleys would be mounted to the crankshaft and camshaft using keys or dowels so could only be installed in one position. So, as long as you lined up the pulley marks with the corresponding marks on the front of the engine whilst installing your new timing belt, you really couldn't get it wrong. (but, unbelievably, people still did!).
Newer engines are now tending to have at least one of the pulleys with no key! So if you slacken the retaining bolt the pulley will spin freely on the end of the shaft. The result of this is, of course, that the timing relationship between the crankshaft and camshaft is lost. To set this "phasing" relationship up correctly again requires a kit of timing tools because with no key on the cam drive there's no fixed point of reference any more! You can buy them on eBay at around the £40 mark (I bought the "Nielsen" branded kit, Pictured in the post). On our Panda 8 valve "FIRE" engines it is recommended to slacken the cam pulley retaining bolt - just by half a turn or so, enough to free the pulley on it's shaft. It's not splined or anything, as soon as you slacken the bolt it will be free to spin without driving the camshaft - However I couldn't see why it is necessary to loosen the bolt in the first place if you make your own timing marks. Which was a common way to do it in my "workshop days". Oh, by the way, from what I've read, it's very very tight! - another good reason not to undo it. Of course it then needs to be done up again, very very tight! (I'm a great believer in letting "sleeping dogs lie")
I set out to check this on both our 1.2 euro 4 Panda and my older boy's 1.4 Euro 5 Punto - both of which needed belts done. Before slackening anything off I made marks (Tippex) on the crankshaft sprocket and corresponding marks on the old belt and oil pump casing then, up top to the cam sprocket, belt and cylinder head/cam cover. Then I removed the old belt, leaving the cam sprocket bolt fully tightened and transferred the marks from the old belt to the new one, replaced the old water pump with a new one (don't believe in doing a belt, where the water pump is part of the drive train, without renewing the pump) and fitted a new tensioner before fitting the new belt so that the transferred marks all lined up as they had before the old belt was removed.
If my theory was correct that should be the job done. So, just to be sure, I removed the cam cover and fitted up the cam locking tool to the right hand (passenger side) end of the camshaft and offered up the crank locking tool. Guess what? it all lined up absolutely millimeter perfect! The same worked on the Punto, which I thought it would but was less sure of because it has the VVT cam sprocket. Of course, and it's a big OF COURSE, if you do it without the tools and rely on your tippexed marks then you are setting it all up to be as it was before you started work. The problem with this is that you can't be sure the sprockets were set up correctly before you started. Unless you know for sure that this is the engine's first belt change (surely the factory will have set it up right when they built it) or you have worked on it yourself before and know, because like me you used the timing tools to check, that the timing is originally correct.
So, for future belt changes on our cars, I won't need to remove the cam cover and other "awkward" ancillaries when we get to belt change time which should save a considerable amount of time. I would not like to do an engine whose history I did not know without using the timing tool kit.
Apparently it is not unusual to perform a "Phonic Wheel Relearn" after renewing a cam belt on these engines. Our local Fiat main dealer said they always do as a matter of course. I used a Gates All-in-one kit which includes the water pump and has quite a good fitting guide included. It stated that an "ECU Relearn" will be needed on completion. So another thing I was interested in checking out was whether a "Phonic Wheel Relearn" would be necessary if you didn't disturb the sprocket bolt. For those who don't know (and I had never heard of a "Phonic Wheel" until we bought Becky - There had never been any reference to it with Felicity - our older 1992 Panda Parade) These later engines have a sensor reading on the crankshaft pulley which mainly tells the ECU where the pistons are and what RPMs the engine is turning so it knows when to fire the plugs but they also have a sensor reading on the camshaft pulley which feeds signals to the ECU enabling it to decide which plug to fire when and, I believe, small trimming adjustments to the timing to take place. - maybe does other "stuff" but I wouldn't know about that. The ECU learns the expected relative position of these two shafts (crank and cam) and if it sees something unexpected it will flag up a DTC (Diagnostic Trouble Code) and store it as an Error which you can read with the likes of
MULTIECUSCAN and light up the check engine light on the dash. It can detect minute changes in this relationship. (by the way, I have read that it often mistakenly interprets this as a misfire code which can really fool people who don't know about it! There are posts in our forum about people who have spent substantial amounts of money renewing plugs, plug leads, ignition coils, etc trying to rectify this when what is actually needed is a "Phonic Wheel Relearn" performed using either the genuine Fiat dealer computer or
Multiecuscan. By the way, there is a bit of an obvious "give away" clue on this one. People who have experienced it say that although the ECU was logging a misfire code there was no detectable misfire when driving!
If you have had the cam sprocket bolt slackened, as is recommended, during the replacement of the timing belt then I can see that there may be a very slight difference in it's angular relationship with the camshaft which will likely be picked up and cause a DTC to be stored and the check light lit. I wondered though that if you don't touch that bolt - so don't alter the relative position of the cam pulley to the camshaft - and with the exceptional accuracy with which modern synchronous belts (that's another name for the kind of toothed belt used as timing belts) are manufactured, they say that they don't really stretch either, then surely there would be no detectable difference between the old and new relative running positions of the two pulleys so timing would be spot on and so no error detected by the ECU so no EML (Engine Management Light) lit either.
Well I'm pleased to be able to report that, more than half a year later, neither car has lit it's EML. For which I'm very glad as I still only have a sketchy idea how to perform a Phonic Wheel Relearn with my
Multiecuscan program!
By the way, on the Panda, probably the most difficult bit is slackening the two (of four) engine mounting bolts which hold the mounting to the front of the engine and "hide" under the mounting itself. the mounting on the Punto is almost identical but easier to tackle as access is better (more room between the inner wing and "front" of the engine).
So, Theleman, You sound to me like the sort of chap who could do this! Read all the guides and have a very good look at the engine first. If you're feeling good about it have a go! It may well take you longer than you think so prepare for what you're doing for transport if it takes more than a day - don't rush it! Often ends in disaster if you do. Also worth thinking about who could help if it goes wrong and you can't complete the job? The first one I did gave me tremendous pleasure when it fired up and idled nicely - I had a smile on my face for days! Last word of advice? On any engine, particularly if you know it to be an interference design, Remove the spark plugs so you can turn the engine over easily and slowly and gently turn the engine - spanner or socket on the crankshaft pulley centre bolt - through two complete revolutions feeling all the time for any resistance (which you will feel if a piston is making contact with a valve) You need to do this slowly, stopping the instant you feel any resistance, because if you do if fast the flywheel will contain sufficient energy to bend a valve head before it stops. Do this BEFORE even thinking about hitting the starter. The engine turns so fast on the starter it will ruin it if you've got it all wrong! By the way, always turn an engine in it's normal direction of rotation - turning it backwards can de-tension the tensioner and make the belt (or chain on chain cam engines) jump teeth and put your carefully set up timing out of synch!
Well, that was another of my lengthy posts wasn't it! Hope it's been of use to some.
Stay well all
Jock
