Hello,
I have a turbo boost sensor failure; error P0235. I believe I have managed to locate the IAT Boost sensor behind the charge pipe on the inlet manifold at the front of the engine and below the large black plastic injector cabling shroud. I have managed to remove the connector and single securing screw for the IAT, but cannot lift the sensor out due to another single red cable connector placed slightly above and at an angle of approx 45'.
I don't want to force the IAT out incase I snap the sensor part off in the manifold, but I am not sure how the single connector at 45' is removed, OR indeed what that single cable is for.
I attach a couple of pics. The blue label is on the IAT and is partially hidden by the single connector.
Does the single connect just pull up and off or is there a non release clip?
Any assistance will be gratefully received.
Eddie.
Eddie.
- Model
- Ducato 2.3 130 Multijet 2007
- Year
- 2007
- Mileage
- 35000
