Technical Installing fog lights afterwards-new power line
ıstanbul
My vehicle does not have the original fog light installation.
There is no fog light relay, button or line.
I want to draw a line with relay and fuse.
I will get the relay feed from the contact electricity.
I'm thinking of running a fused line from the battery with a 2.5mm cable. I will control this line with a relay.
But I don't know how to get the power line for the button to the dash.
Does anyone have any suggestions on this subject?
I have plenty of time. I'm progressing quite slowly. I opened multiple topics at the same time. I look at different issues piece by piece. I'll be waiting, thank you :):)
Im doing a guide which hopefully will be done in a day or so which should show you how I did my fog lights. They are still working after two or three years and looking at how its done Im still pleased with it. I will let you know when the guide is up and available.
Wonderfully simple and effective. :D:D
Thank you.
The only question in my mind is;
How did you connect the power cable to the front panel?:unsure:
when we push it through the harness. Does the cable fit behind the front panel?
I couldn't figure out how to get the cable to the cabin.
Thank you.
If you look at the photo withe the relay, in the top left corner you will see there is a plastic grommet in the bulkhead. I made a hole in this and pushed the wire through. I have a fiberglass rod which I used to push through, and pulled the cables into the car with this.
