Oh and btw another modification you can do to it to improve it is increase the rigidity of the elbow. This can be done by putting another jubilee clip around the elbow at its 45 degree angle and tighten a little.
I will get a picture for clarity. It makes a noticable difference.
vacuumhose for map or similar, if you do not have a spare vacuum hose when you remove your intake then you dont need the hole and you can block it up (the correct size bolt and a hose clip works nicely)
Matt, wouldn't it have been easier to connect the breather at the elbow and blank off the hole in the metal tube rather than link the original breather and the smaller diameter pipe?
