Hello
My 1.2l when turn the key to start motor , it beeps , writes "excess coolant temperature please turn off the engine" ( or close to this ).
It lasts about one second as the engine started , then everything goes to normal .
When it happens , that water temperature gauge jumps to max and red light is on.
As said all this occurs on the moment the engine starts.
Coolant level is a bit higher then 'MAX' like two cm.
On driving every thing is OK , temperature slowly rises from min to middle normal and stays there during the drive.
What's can be the reason for this ?
Thank you
Thank you
