Hi everyone,
I recently bought a used Fiat Grande Punto 1.3 MJT (2009). The car came with a remote battery disconnector installed (located next to the fuse box inside, driver side). I later discovered this was used as a workaround for an issue with the lights.
Here's the problem: after turning off the car, the headlights turn on by themselves about 30-60 seconds later and stay on indefinitely, draining the battery. This happens even if I turn off the lights manually using the stalk before switching off the ignition—they somehow override and come back on.
This behavior occurs regardless of:
There are no OBD error codes and I haven't noticed any other electrical issues.
I'm wondering whether this is triggered by the BCM going into a sleep mode with something malfunctioning and then the failsafe is lights on?
Any suggestions on how to narrow down the issue?
- The key being in or out of the ignition.
- Whether the doors are open or closed.
- Whether the car is locked or unlocked.
- Model
- Fiat Grande Punto 1.3 MJT
