Tuning handling
Tuning handling
How are you mounting the rear coilovers?
Think ill be mounting mine to the cage some how.
Ill be running on 15" wheels tho so dont have a clue how much i can lower it by.
What size rims you on then?
i took the springs and dampers off the rear of my old cinq and dropped it, you can go very low!!!! theres plenty of space in the arch:D
If i lower my sx 60mm it is the equvielent of droping a sporting 40mm.
has anyone dropted there sporting seicento 40mm, if so how did it handle?
thanks for the positivity pal, as for the strut brace. Ive been looking on the net and can only seem to find them for a sporting, will a aftermarket sporting strut brace fit a sx seicento??
looked on strutbracer.co.uk
get a strut brace for a 98-00 sporting though
the 01-04 ones are modified in order to bypass the ABS box (if it has ABS fitted)
ok i have got a 97 cinq sporting and i am lowering it and it is not advised that i get a lower brace is that right cos i have like a mile of space under the car (as in i can almost slide under without a jack) yes i am going down 60 on the front so would i hit the speed bump problem
yes, not only speedbumps to worry about, think of potholes etc
maybe not an effect at the minute but when you lower it it could be a problem
ok i will lower then have a look as potholes aren't much of a problem around here but speedbumps are a plenty well its going low on tues if everything goes to plan but they may only be -40mm on the front as apex dont do -60mm from what i have found but we will see
