Technical gearbox 6 speed drain and fill pulg
shotgun
Established member
where is the drain and filler plugs on a 6speed gearbox 2008
What size engine? I can steer you in the right direction if it's the 3.0lt.
Edit - just seen your other thread and I guess it's the 2.3lt, sorry,
Hi
Here are some diagrams for the location of the filler plug & the drain plug for a X250 2.3lt. with quotes from the X250 eLearn - left Picture is location of drain plug & RH Pic is the breather/filler plug.
1. Remove the gearbox fluid bleed/filler plug.
- Position a suitable container under the vehicle to collect the fluid.
1. Undo the plug and drain the gearbox fluid into the container positioned previously.
- Clean the drain plug, apply a suitable thread-locking agent and tighten it to the recommended torque.
Gearbox oil plug Plug 3/8"x10 Torque - 2.2(daNm) 2.3 JTD
Component
Manual gearbox/differential fluid
Type Oil
Description TUTELA CAR EXPERYA
Classification SAE 75W-85 API GL-4
Quantity 2.7 l
Validity 2.3 JTD
See attached pics
Cheers
  • Like
Reactions: CDK
You may find a reverse switch where the fill plug is marked on diagram, no problem just unscrew and fill through hole
