Bravo my man please help me I bought a set of HIDs the arrived today and I can get them fitted ok but you will know this as you have already done it
the standard bulb has only 1 spade on theback of it and the connector has only 1 slot for it to go into
Now My H1 kit has to wires a red one and a black one both have spade connections which goes where the instructions are not clear enough. As far as i can see i have 1 too many wires lol
here is a link to the same setup i have
http://forum.2gn.org/viewtopic.php?t=30192
scroll down the page till you get to the 3rd pic of the H1 kit and its the same layout as mine
Check the back of your headlight unit. There are two wires. On the Bravo though one wire is connected to the bulb direct (the one you have found) but the other is actually attached to the housing the bulb sits in just to the side of the bulb.
Take a peek and you should find it.
If I remember right. The red attached straight on to the bulb and it's a black wire that is connected on to the housing.
It's there though and your HID kit will fit and work ok from what I can see in the photo
Any other questions give me a shout and I'll help as I can.
