Technical Fiat QUBO Blue&Me Removal
Filxomor
Hi to All
i had probleme with Blue&Me on fiat qubo 2012 1.3jtd
i have removed it
but now i have AIRBAG light on dash
when i diagnose the airbag i have not errores
i have changed airbag module
please help
proxy setup is finished ok
please any help....
before i did many times in others cars
always was OK
Model
Qubo
2012
Mileage
115001
No, i did not disconnected the battery
Before i did many cars as alfa 159 147 fiat 500 etc...
Always was ok
It's a very common problem, widely discussed on different forums. The nowadays cars are more computers than only mechanical machines. They contain several electronic modules which are very sensitive to voltage variations. Looking at the screenshot the Qubo has 9 of them.
My Ducato's BCM looks like that stripped:
Other ones might be even more packed (the airbag module, ECU, ...)
In the Ducato owners' handbook there is a procedure on how to disconnect the battery. Some specialist even say that after disconnecting the battery and before disconnecting the modules lights or other electric equipment (preferably connected to the module to be disconnected) should be switched on / off a couple of times or for some time to get rid of the parasitic voltage and voltage in the capacitors.
Apparently the airbag module can be repaired in most of the cases. There are two companies in the UK, one has better opinions than the others. If interested, you should be able to find it quickly on the forum. Planning to add a passenger airbag in my Ducato I've also found a guy in Poland that says he could repair such errors (and reprogram the module), but I have no experience nor other feedback on his services.
I think that such services should be available also in Austria, Germany or Czechia ;) You should try to search on the internet.
I'd of course try disconnecting the module AFTER disconnecting the battery and let it like that for some time, but having read lots of threads I know that usually it won't help :(
but i have changed airbag module too, no succses
Not errorrs in airbag module
Just on dashboard
So no issues with any recorded airbag errors?
The airbag light is on and no reason why ?
Why would everything be fine but then it throw an airbag warning light after the blue and me module was removed?
Does the body computer have any errors? Does it know the airbag light is on ?
You can cycle the airbag light on and off in the body computer on MES, so you should try that and if the light stays on then you have an electrical issue and not a software issue.
Try that and see how you get on
