Thanks Jack
I think this is for different threadIF you need it to drive home
Tape it up and slide finger of a Marigold glove over it
Path of least resistance is still the Plug gap![]()
Good pointI think this is for different thread
At least it's unanimous that the engine lost compression.You need Fuel, you need a spark, you need air and you need compression. If you have established you have fuel and a spark, the next logical step is to make sure you have air and compression which a compression test will tell you. Continually trying to start the engine is just going to flood the cylinders, wash the oil out of the bores and risk causing damage to the engine.
If the oil washes out? How can it get back in there?wash the oil out of the bores and risk causing damage to the engine.
A how to, for running a compression test on this engine, slightly older engine but the process and the basic engine is the same.
And #4 is the battery / gearbox endAre you sure you've got the plug leads on the correct plugs? I don't know this engine/coil pack but I'd imagine that the pack is numbered by the connections?
Thanks, Yes the engine used in My Mk1 Punto Cabrio is basically the same engine as in your car with very little difference.I just noticed it's your Youtube channel. It's a pretty good video, easy to follow. Kudos
There should be 3 bar there. When you say fuel comes gushing out that does not sound right to me. There is quite a bit of pressure there. Sufficient for it to be intimidating to press that valve. It is a bit awkward but it is possible to take the injector rail off and keep it electrically connected so you can crank the engine and watch the injectors spraying into some containers. Each injector has a built in filter. It is possible to reverse the injector in the injector rail to get petrol to come out in reverse thru the filter
- Checked that there is pressure in the fuel injectors rail, I don't have a value for the pressure, but pressing the valve on the rail, with a screw driver, fuel comes gushing out
Yes, when I pressed the relief valve a burst of fuel sprayed all over my hand. I can't say if it was 3 bar, but it had quite some pressure.Sufficient for it to be intimidating to press that valve.
I only unplugged the electrical harness of the injectors, I didn't removed them from the injector rain/manifold.(...)but you didn't mention re-connecting the injectors after blowing the cylinders out (...)
but if you haven't already I'd walk away from it for a day and come back and check everything for mistakes with a clearer head.
I don't remember listening to any unusual noises.Going back to the rough idle which started all this, did you hear any different noises?
Yes, I had the air filter off. I had previously removed the intake manifold, some 4 years ago, and there I can't see anything that would be upset about that. Despite maybe the intake valves?I presume you had the air filter off when you blew the cylinders out with a compressed airline? Anyone know if there's anything in the inlet tract that could have been unhappy about reversed flow if an inlet valve was open at the time?
The mechanic told me to keep trying to start the car. That is probably sooth inside the engine that is jamming the valves, and the car will start and clear the "debris". The origin of these debris or sooth is from me cleaning the spark plug threads on the engine head.
I am gonna try to use Starter Fluid to see if I can start it before the battery dies out for good.
Do you guys think this could work?
I can hear a sound from the exhaust pipe, is hard to describe it, but that noise is also audible at a different tone in the engine itself.Going back to the rough idle which started all this, did you hear any different noises? A stuck inlet valve can sound like a chuffing noise from the air filter and a burned exhaust valve more of a spitting noise from the exhaust.
What you suspect it might be? A stuck valve? Maybe a head gasket? The engine seems to have regained compression. Honestly I don't know how weird, or incorrect the claim might be.Something is very clearly not right. I still very much doubt the Soot Claim.
Have you checked for any massive air leak eg cracked manifold or intake gasket leak?
