Hi All
I have a 2015 Fiat Ducato.
I think I have a problem on Can Bus B with is the low speed can bus.
With a ODB2 break out box both Can Bus C high speed bus and Can Bus B low speed bus show they are working o/k with key turned on.
Using Multiecuscan I can read all the modules in the van on both C and B can bus with key turned on.
Checking proxi alignment all modules show up o/k with key turned on.
When I check for terminating resistor on C can bus with the power disconnected I read 65 ohms which is within range.
Checked on pin 6 and 14 on ODB2 terminal.
When I check for terminating resistor on B can bus with power disconnected I have open circuit. No ohm reading.
Checked on pin 1 and 9 on ODB2 terminal.
When the key is turned off I get 11 volts on ( B can bus ) pin 9 of the ODB2 terminal.
Question is.
Does pin 9 ( B can bus ) on the ODB2 with key turned off normal for it to show 11 volts.
E.g Does pin 9 ( B can bus ) not go into sleep mode
Is there a terminating resistor on the low speed B can bus.
If so where is it.
Thank You
Graham O
Question is.
If so where is it.
Thank You
Graham O
