Thanks for taking the time to post this document, although I attached the whole document as an attachment earlier in the thread. The ECU is dated 2023, so it was replaced and not reset. I didn't manage to clear any codes as the body computer won't talk to the Airbag ECU. I did the proxi align which then basically thought there was not an airbag system fitted at all!
Agree with your "I'd disconnect the battery following the procedure from the owners' manual (which prevents damaging the airbag module!), then try to discharge any residual voltage from the system and yourself and then disconnect the module, which will allow you to check if there's continuity between the plug and the F50 fuse." comment.
I've already made an additional earth which didn't help with this error.
Mondays job!!
True, I have not checked the contents of what you've posted, looking at the title I assumed it's only the wiring part. Sorry.
Two more thoughts:
what is the interface you're using to connect to the OBD port? I have no idea if the has an impact on the BCM / airbag module connection, but normally the airbag module requires an OBD cable + the yellow adapter to connect to the airbag module. Alternatively the bluetooth adapter can be used.
Isn't the airbag module from 2023 too new? I know FIAT messed up again with the electronics / equipment (possibly also with compatibility) in 2021... Who did the module replacement? You wrote that it was 550 GBP. Have you got an invoice? I'd check with them first, especially you've said it was before you've bought the camper 5 months ago. Was the odometer blinking since the purchase? Or it just happened recently?
Have you played with seats? Or with the starter battery?
