Technical Ducato x250 gearbox swap
knupz
Bucharest
Did any of you had experience with gearbox swap on x250 ducato from 5 to 6 speed ?
The engine is 2.2 puma origin p22dte code 4hv 74kw 5 speed and i was looking for a easy swap, more precisely the 6 speed gearbox hooked up in boxer/jumper engine code 4hu 2.2 90kw due to variable geometry turbocharger, rest of engine is identical.
Any thoughts ?
Any thoughts ?
Only that all the gear linkage , cables, gear stick etc. will need to come from doner vehicle.
Also check if same type clutch operation, external slave cylinder or concentric clutch.
Also any switches sensors etc. as not just the reverse light some also tell the computer what gear you are in, which may be an issue.
All this is assuming all mounting points etc are the same and the type of clutch is compatible.
