I have an Adria Sunliving on a fiat ducato base 2914
The horn stopped working so used the forum to help
Checked all common problems-
fuse good
relay T03 works
horn itself works
Removed steering wheel and checked connectors etc one has earth fine other wire does not have continuity to relay
If I bypass it from relay to circular wire on horn pad then press spring connector horn works thus diagnosed broken wire
Removed unit under steering wheel tested this ok
Got to black wire in steering column loom and connector under fuse box under bonnet
No continuity
Took off dash panel around steering and loom seems to go straight down column into main loom then through firewall to engine bay
Does anyone know or have a full wiring diagram to show and other loom connector I have missed that may be corroded etc before I start cutting and patching into my loom to bypass this
Sorry so long winded
Thanks in advance
fuse good
relay T03 works
horn itself works
No continuity
Thanks in advance
