Technical Fiat ducato 2.8jtd 2004
Tarren
Preston
Hello. I have a problem where I've lost the low beam. I've checked fuses etc, swapped the stalks even but still no low beam. I get side lights and back lights. I still get hi beam but won't stay clicked on anymore. Also rear fog lights, reverse light and interior dash lights. Pretty much all at once but no idea when or how. I swapped the radio but other than that nothing. Any help would be much appreciated. Tia
Model
Ducato 2.8jtd
2004
Mileage
51000
Hi Tarren,
Just noticed your post. Welcome to the forum.
For a possible cure to your problem check fuse F24 in LH cab fusebox. It is the right hand of three 5A (Tan) fuses in upper row. Even easier for starters is to check that the instrument panel and number plate are illuminated. (Both should be lit.)
Attached are Fiat eLearn diagram for dipped beam with my notes added, colour code translator, and fusebox layout.
Rather than TIA please post your findings on this thread.
  • eLearn E2011 Dip Beam.pdf
  • Fiat Wiring Colour Codes.pdf
  • Fusebox B002 Cab LH.pdf
