I’ll be checking what I did with the fuel pump gasketing today - I can’t recall if I added a gasket between the spacer and the pump.
Having spent a lot of time trying to ensure I had one ‘good carb’ from the two that came with the car, coupled with the small fortune I’ve spent on this project so far, I took the plunge and ordered a new Weber carb from Ricambio yesterday.
As for the air bubbles in the fuel line (pleased I used the original green transparent fuel line), I have tightened up the various joints between the tank and the carb. Only issue I could find was a small nick in the rubber gasket under the sender unit.
Let’s see what the weekend brings.
And thanks again.
Peter
