My understanding is that the immobiliser system was operational on both vehicles. As @RunarBolstad has not definately stated that he wishes to remove the immobiliser, suggestions have been tailored to test run the engine, while preserving both options.. As I understand it, removal of the immobiliser is slightly destructive, and replacement may not be an option.Least complicated way is to remove the part of imobilser that is on the injection pump. You will then just be left with the simple stop solenoid on the pump that requires +12volts to enable vehicle start.
Yes, and a presence of an immobilizer is (or at least was) also a requirement in the EU for insurrance. And is a simple anti-theft device for non experienced / non prepared thieves.My understanding is that the immobiliser system was operational on both vehicles. As @RunarBolstad has not definately stated that he wishes to remove the immobiliser, suggestions have been tailored to test run the engine, while preserving both options.. As I understand it, removal of the immobiliser is slightly destructive, and replacement may not be an option.
Sorry @RunarBolstad , I do not think that we fully answered your questions.I took the donor key and held it with the camper key when cranking.didn't work. So much for proving the these
So how does this security work exactly? Where are the measures? Chip inside the key? Receiver in the ignition lock?
Signal goes to fuel pump thru wires or radio waves?
I used my voltmeter and found out that the solenoid have 12 volt either way? and that there are communication between the reciverbox and the pump. So i guess that the handshake between the immobilizer system includes a small circut board inside the diesel distributor as well.Least complicated way is to remove the part of imobilser that is on the injection pump. You will then just be left with the simple stop solenoid on the pump that requires +12volts to enable vehicle start.
Yes, there is a circuit board in there. There are photos somewhere on this forum.I used my voltmeter and found out that the solenoid have 12 volt either way? and that there are communication between the reciverbox and the pump. So i guess that the handshake between the immobilizer system includes a small circut board inside the diesel distributor as well.
It worked to hold the donor key at the right spot. On the rim of the ignition there are som marks, and on the key there are an antenna. The get this to work the donor key must be between the mark and the antenna mark on the original key. Then the immobilizer lamp turns off, and the car starts.USUALLY the transponder in the key is a small element with no external electrical connections, but with an iside coil, which is activated by induction. No radio waves, but close proximity to the antenna (which USUALLY is located around the contact) is needed. That's why I suggested putting the donnor key close to the recipient's contact.
According to ePER:
Variant 2 shows another form of ECU (no 1) on the diagram.
The question is if the receiver will get two signals, which one it will take into consideration. Or perhaps they will interfere and nothing will happen.
Do I close the thread in some way?That is really good news , thank you for letting us know you have a fix.
Best wishes
Jack
No. That formality is not required.Do I close the thread in some way?
Apparently there are two special security bolts with snapped heads. You need to cut them off in order to remove it from the steering column. It's an anti-theft solution. You can of course replace them with classic bolts with normal heads. They snap where the rubber band is.Final solution for me will be to change to ignition barrel
