Hi there,
Just wondering if someone could possibly offer some advice, please?
I've got a 2010 Ducato 2.3 X250 which is a Campervan conversion.
On a recent trip out with the van I found that the dreaded airbag light illuminated when starting the engine and has stayed on for the last few weeks.
Looking at the battery compartment, I've found the ECU unit and that this is a 1358990080 TWR Airbag ECU.
I've connected the 'van to MultiEcuScan to check what the issue is and that reported a code of B1001 - Control unit faulty.
Therefore my assumption is that the Airbag ECU can be communicated with, but it's not working correctly. I'm not sure whether this is likely to be a software/firmware fault (needs re-programming) or whether this is likely a hardware issue and I need a new airbag ECU.
If do I need to replace the ECU entirely, I found a reference to 1358990080 on https://eper.fiatforum.com/sr/Drawings/Detail/F/T/D06/2J/555/8/0/1/0/SubSubGroup/1371008080 and have found that there are several other model numbers for that ECU as 1358990080 units do not seem to be that common.
Silly question - does anyone know if any of the successor units (1367537080, 1371008080) be used as a direct replacement for a 1358990080?
Also, just wondering if TWR Airbags of this type (not the 2 series) still need Proxi alignment or not?
Any help most would be very much appreciated.
Many thanks,
Sean
Many thanks,
Sean
- Model
- Ducato 2.3 X250
- Year
- 2010
