Bag E Puss
- Joined
- Feb 1, 2016
- Messages
- 6
- Points
- 1
Hi, I've had an occasional problem with this for a year, but for the last week the side marker lights have come on every time I lock the cab doors. I have a Dethleffs coach built Motorhome, but I think the problem is originating on the Fiat side. Here’s what I’ve found so far:
- Fiat remote keyfob will lock the doors, and lights come on after 1 minute. Fiat remote keyfob unlocks the doors and lights go off.
- Surprisingly, my Audi remote keyfob will also activate the lights, and deactivate them, but won’t lock/unlock the doors.
- I can hear what I assume is a Dethleffs installed relay clicking under the passenger’s seat whenever the lights switch on or off.
- Pulling the red fuse blade will deactivate the side marker lights and the relay (in photo).
- deactivating the Motorhome installed Schaudt Elektroblok EBL-99 (which controls habitation electrics) has no influence over the marker lights. The marker lights are on a separate circuit to the rest of the Motorhome electrics.
- turning sidelights on via the knurled wheel on the steering wheel stalk will turn the side marker lights on, and the relay clicks, even with ignition key out. Other side lights don’t come on.
- high level marker lights (red/white) are not impacted.
Am I right in assuming this is likely to be a fault in the CANBUS signal to activate lights, from which Motorhome builders take a feed (and use it to activate a side marker relay)? I understand that feed is via a plug in the drivers B-frame by the driver’s seat. I haven’t checked there yet.
What else can I do to isolate the fault? It is weird that the remote locking function responds to another manufacturer’s keyfob (at least in activating lights), which is why I am thinking this fault must originate in the Fiat CANBUS system.
Look forward to any advice.
