Technical Drive belt and Alternator pulley
Well you can't change an alternator pulley, the're connected to the alternator and come as one whole unit (unless i'm corrected by someone else). The noise is likely coming from the crankshaft pulley. I think you said somewhere above you had a new water pump? If so it'll be a consequence of that job.
The sound in this video is not that of a failing clutch in a pulley (cos you don't have one). But does sound like the of a whining bearing in the alternator itself...
So need a new whole alternator? This is covered under warranty with the used car I got I believe.
