Adam1984
Hello.
So I have come to conclude that I need a new drive belt and an alternator pulley. My symptoms are somewhat similar below:
A faulty overrunning alternator pulley can cause unusual noises, vibrations, and potentially lead to belt issues, battery charging problems, and even overheating, requiring replacement.
Here's a more detailed look at the symptoms:
1. Unusual Noises:
Squealing, Whining, or Whistling: A faulty pulley can cause high-pitched noises from the engine compartment.
Buzzing or Chirping: A short buzzing sound (1-5 seconds) during engine start-up or shut-down can indicate a worn bearing in the pulley.
Rattling or Ticking: A loud rattling or ticking noise from the engine at idle can be an early symptom.
Grinding or Squealing: A failing pulley can cause a grinding or squealing sound to come from your engine.
Vibrations: A worn pulley can cause vibrations in the belt drive system.
2. Belt Issues:
Belt Slippage: A faulty pulley can cause the belt to slip, leading to a burning rubber smell.
Excessive Belt Wear: A bad pulley can cause the belt to wear out prematurely.
Belt Misalignment: A faulty pulley can cause the belt to run off-track.
3. Charging Problems:
Battery Not Charging:
If the pulley is bad, it can lock up or spin free in both ways, preventing the alternator from charging the battery.
Dim or Flickering Headlights:
A faulty alternator pulley can lead to electrical issues, such as dim or flickering headlights.
4. Other Symptoms:
Engine Overheating:
A faulty pulley can disrupt the smooth movement of the belt, causing it to heat up and potentially lead to overheating.
Engine Accessories Stop Working:
If the alternator pulley fails, it can cause the engine accessories (like power steering or AC compressor) to stop working.
Burning Rubber Smell:
Visible Wear:
Look for scoring marks or damage on the pulley itself.
Pulley Feels Loose:
If the pulley feels very loose when you try to turn it, it could be a sign of a problem.
So my question is, I need a 4 Rib belt as I don't have air con on my vehicle.
But I can't seem to find a 4 rib alternator pulley. Do these exist or do I have to buy the alternator as a whole?
Thanks.
1. Unusual Noises:
2. Belt Issues:
4. Other Symptoms:
Engine Overheating:
Visible Wear:
Pulley Feels Loose:
Thanks.
- Model
- Panda Pop 1.2 Petrol
- Year
- 2015
- Mileage
- 60500
