Yes that the ccm .Ok I m not sure if this is climate control , but checks back to the relay however it’s disconnected so will see if the fuse blows
fingers xed you get a win.
To energise the starter use the battery live connection at the starter , connect a short piece of wire to the trigger connection on the solenoid(the small wire on the solenoid)Ah well it hasn't cut out the cooling fan and the heater fan doesn't work connected or disconnected now . If the ign key is on and the earth post replaced all the indicator lights come on and stay on . The relay shown earlier clicks at the same time without the fuse which has blown again. Ha this crazy, it feels like power is being gained or earthing is being gained from your high resistance , question is where. I will go up the back tomorrow or tonight , I will see and reconnect the alternator figure out a way to trigger the starter . I can get it energise with the key but doesn't throw completely, so lack of power/current?
Crazy man!
I would be thinking of checking the high current circuit that feeds the starter motor before pulling out the starter motor.Starter does not engage manually by energising the solenoid so I guess that has to come off.
I m thinking you still think the real current isn’t being transported via original cables . So what your saying is a new path for both - and + leads to engine block to eliminate resistance ?
I am trying to go one step at a time.Why not isolate the starter.. and see IF your dash issues stop..
Save lots of guessing![]()
No that's not what I am saying(though that would work)Ok I think I see what your saying , make up a single feed to starter from battery And like wise for earth. Can get that made up easily. Forget trigger wire I can do that from main new wire ?
You would have to make a clean break for both leads to eliminate any bad connections originally in place , surely .
You and friend rebuilt all of what exactly?With all this going on and looking at this taking a step back, I , with my friend rebuilt all this with replacement unit and connections were all clean this was only last October.
I understand now that engine and gearbox was replaced last year.Replacement unit s/h of course, excellent engine and gearbox.
Old engine was overheated then belt went. Whole car bought like that. Yeah so quite fresh
