Well here's the latest of the 'Things to make you go Hmmmmm
Have noticed that just before passing 10,000 miles on the clock and a year old the HP has presented me with a new noise....... a creaking sound coming from inside the steering column housing.
This originally manifested itself with a slight creak on slow speed turning right......now we have it everytime I turn the wheel - in any direction.
At least it can clearly be heard when parked and 'rocking' the wheel from side to side - so definately relating to the steering column - so can I assume that some lubricant has taken a year to dry out? The steering column housing appears to be secured by a single cross-head screw underneath....... I can't be bothered to take the car into the dealer - particularly bearing in mind the car was there for its' first service only a week ago. So before I get tore into removing the housing, locating the 'dried out' element and lubricating if possible, has anyone else experienced this?
Sounds like a plastic/nylon rubbing creak so white grease rather than 'cure it all' WD40?
Or should I just take it back in and say....."why should I do it?"
