ernielionel
Hi there. I've got a Fiat 500 with a problem. When I press the clutch in it won't let me select any gears. There is pressure on the pedal. I've replaced the slave cylinder and fitted a compression fitting where the old joint was leaking. It's been thoroughly bled but still won't let me engage the gears with the pedal pressed. Any help would be appreciated thanks. Mick
