Driving style has a lot to do with it - I've not needed to replace a clutch in any of my cars since 1989; I kept two of them for well over 100,000 miles and one for well over 200,000.
OTOH, TopGear's Liana (star in a reasonably priced car) went through 400 tyres; its brakes were changed 100 times; and it required six new clutches, two new hubs, driveshafts, wishbones, struts and gear linkages and a replacement wing mirror
Mad that, about Top Gear!!! So that's what the license fee gets spent on, still, that was the only show I think was worth the money! (probably the only one that generated anything back too! haha) apologies.
Although I've had my license for around 2 years now, and a claim and a dent (not claiming to be the best driver) but I am very respectful and gentle on the Panda since it's my responsibility, and I love the fact its my very own, quite unique little Italian car. Now, my granny drove it for years since it was 2 years old, I doubt it got past 40 much lol My sister owned it from 2013-15 and she is notorious for destroying cars due to trusting a crappy mechanic and being careless. A friend even remarked to me about how she drove the Panda out the street (like some sort of Land Rover) she also drove a Mitsubishi Shogun 2.5 her bf drove not long before the Panda so maybe it was her who ruined the clutch?! In my defence, I've had it since October and since then have only stalled it about 10 times max!
I'm very interested now in this 'AP' kit and hope it lasts longer than the OEM (Valeo?) part.
Its best to buy the gearbox bearings when you have the old parts out of the box. Then you can be sure of getting the correct version. The bearing factors will offer various options and most likely have them in stock they are a common size.
Being a biker I learned to match revs from day one, but my clutches all seem to go at about 80K. Bikes don't have synchromesh and crash badly if you don't shift correctly (but you can shift smoothly and very quickly without the clutch).
I'll look for a suitable part, unless you can link me to one? What difference will this make in general to the driving experience? Or is this a part that simply works behind the scenes to keep it all right?
Perhaps when the mechanic takes to the job, if I specify I NEED that part be replaced he can get it? Even though we're in rural Northern Ireland and Fiats aren't the most common car - hopefully local motor factors will have it?
People have told me its the synchromesh on my gears causing the reverse to crunch, sure enough, if I pull up the syringe mechanism, slowly, push it toward the RIGHT, and slowly toward the 'R' it'll go in quietly. If the window is open you still hear it 'click' in even smoothly. Otherwise it's a horrible machinery 'grind' I mention a lot.
Hoping if I get this master cylinder and new clutch (and bearing I'm learning about here) then that'll get to the bottom of it?!
Knowing my luck, I do all this.. mechanic says the gear box has some sort of irreparable damage.. goodbye £1500+ I've spent since October on this car.. hello crappy used Corsa or something :bang: Hence why I'm always looking to keep the Panda in good shape - to avoid future 'you should have fixed that back in XYZ' damage :thumbs:
Thanks again guys, always enjoy reading your replies. Love Fiat Forum, probably why I love this car so much. When I had a Corsa and tried a few of those forums it was literally full of spanners who only knew how to weld exhaust tips on
