Its getting there. Had a break from the engine at the weekend and moved on to the wiring which is not too far off now. The engine is coming out again this week so I can finish welding and tidying up the engine bay as well as paint it and put all new brake pipes in. A friends dad who owns a engineering company said he will make me some 1 piece driveshafts when I give him the lengths to save welding the two together so hopefully they will be stronger(all I have to do is pay for the material, Result!!). I have aqiured a higher pressure fuel pump so that got to go in too. Yeah it is tight in there for working on but I work on forklift trucks for a living and you should see some of the spaces they expect you to work with on them! the cinq looks spacious! I am going to have the battery and the bottles for the coolant, washers and water injection iside the car in order to get as much air around the engine as possible. I am going to use an electric water pump to overcome the problem of the standard waterpump pulley rubbing on the body and use 2 cinq rads run in series(one on either side of the car with the intercooler and oil cooler in between as the electric pump has the power to do this. Hopefully I have thought of everything as its probably too late now! I will have more pics soon.
Rich.
Rich.
