Something tells me he isn't going to listen to anyone....![]()
Yup. I'm just surprised he hasn't asked about your avatar
Hihi.... no one can say that a standard Panda with standard 13" wheels will handle better than the same car with 15-16" wheels. With the standard 13" the car will skid and understeer even in leagal speed.
And yes, you can at some amount balance the understeer with rims and tyres. Just take a look att the Opel Speedster (Vauxhal VX220). Just change rims on the car and the handling improves extemely much.
And ofcourse I will not have my Panda as a trackday car (have an Opel Speedster). It will be a comuter car. But just to stopp the car beeing everywhere on the road I will mount some bigger rims and tyres. And it make the car look better to.
Although it's a little bit scarier, I can get through long sweeping corners almost as quick in our Eleganza as I can in the 100hp....Yes there is body roll and yes there is more understeer, but it certainly has 'feel'....The 100hp comes into its' own in twisty sections though....However it's not just the wheels that make that difference.
I used to have minis back in the day and the tyres really are a major factor in the handling....There aren't many cars that can live with a mini on 10" x 6" wheels with 70 (!) profile tyres....However stick 13" wheels on it and it kills the handling....![]()
I should also point out that if you can get a modern car to understeer at legal speeds on good roads then you must be a pretty terrible driver. Sounds more like there's a nut loose somewhere behind your wheel.
You do know if you'd kept that Mexico it'd be worth a packet now!A standard panda on standard wheels and tyres driven at legal
(60) limit around a corner MAY suffer the symtoms of understeer,could be low tyre pressure, worn tyres, damp road,but so could one on wider low profile tyres, i agree you must be getting close to speeding or have the wrong approach speed for the corner, i think this is one of them topics where there is a technical reason why you should'nt change and a visual reason why you should, back in the 80s (here we go) i had a Escort MK2 Mexico 1.6 Pinto and rear wheel drive, we all stuck to 13" wheels(nothing any bigger available) but changed the rim style, when 185/60/13s came available it improved the handling a fair amount, up to then the cars had 175/75/13 ? understeer was not a real concern, the handbrake was used and more power applied to put the car into oversteer, a much nicer way to slide but not at legal limits i might add.
My list of sporty cars since passing test in 82/3 ish
.... Talbot Sunbeam GPA tarmac rally car bought to do night navigational events.....
You're talking out your arse if you don't mind me saying so.
The VX220 had all of it's handling work done by Lotus. You know Lotus, the guys who are EXPERTS in regards to handling, the company who had a successful Formula 1 team and who make some of the best handling cars on sale today.
The only thing you're right about is that a car can look a bit better sometimes with bigger rims to fill the wheelarches.
So Lotus with all the money and expertise they have "forgot" to put big wheels on the VX220 to make it handle properly. Pull the other one! You obviously have no idea how cars handle or what influences whether a car understeers or oversteers. Do you seriously think you know better than Lotus?![]()
If you let the wheel alignmet be standard and just swopp to bigger tires you will cut alot on tracktime, I now I have done int myself. Opel and Vauxhal wanted the car to under steer more. That's why they have the tyres they have.
I think there's a small amount of confusion on this threadAs I'm sure you know, understeer is where the rear of the car has more grip than the front (and you crash into the hedge forwards) and oversteer is where the front of the car has more grip than the rear (and you crash into the hedge backwards).
You say the car is set up to understeer from the factory which will be done by suspension geometry, ARB thicknesses and the relative grip front-to-back of the tyres - most powerful RWD cars will have bigger tyres at the rear which may cause understeer.
So, if you increase the grip at each corner proportionally (and by a reasonably small amount), the car is still going to handle in the same way because all the factors are still the same. The only difference now is that it takes more speed to overcome the grip the tyres have to reach the point at which the car understeers.
So, with a wider tyre you're seeing better laptimes because there is more grip available, and you're not overcoming the amount of grip required to induce understeer. Push the car into a corner faster however, and it will eventually arrive.
There was an excellent example of this on Top Gear where the ham-fisted Clarkson was complaining that the new Lotus Elise understeered to high heaven when he was driving it. The Lotus test driver took him round the same circuit and showed that it didn't at all, but as a way of overcoming it for their customers who were not great drivers, they offered bigger tyres for the front only (to change the ratio of grip front to back) and make the handling more neutral.
Chris
So what you are saying is. Bigger tyres more speed = better handling![]()
Grip is also handling
No it's not! A classic Impreza turbo has tonnes (and I mean comedy amounts!) of grip, yet handles poorly. My diesel Mondeo did not have as much grip, but the handling was far superior.
Grip is to do with the tyre/tarmac interface. Handling is to do with the car's dynamics. Ergo you cannot improve handling by increasing the tyre width on every tyre.
Chris
YesSo lets get this right...
If I get 20" spinners wit rubber bands on, then I can get to work faster and cooler?
And The wider my tyres, the better handling i have?
And if I put a "cossie" wing on my panda I will be able to drive upside down in a tunnel at 80mph?
and If I get Go faster stripes, they will add about 10mph.
and if I............:bang:
