- Joined
- Mar 1, 2014
- Messages
- 4,579
- Points
- 828
You'd be surprised. I picked mine up three years ago, the scrapyards are probably swimming in them now.
That's actually quite sad.
Not sure about the height of the TA, it's the 500 Abarth that I found was very tall, probably too tall for a Panda. I'm only at the tape measure stage though so may be proved wrong when I physically offer it up.
This surprises me as it's basically the same lump as the 1.4 16v people chuck in Pandas but with a Turbo on the front.
Does the 1.4 16v have the extra 2" of bracing between the block and the sump?
Don't suppose any of you know how to remove the steering wheel on the panda?
depending on wheel type its either a couple of screws at the back of the wheel (or prise it off with a screw driver) holding on the horn push then just a 22mm nut to undo. Undo the nut to the last couple of turns then pull the wheel off. You can take the nut off then yank the wheel off but you risk losing a couple of teeth![]()
I had a quick go earlier and I have two screws behind the steering wheel I undid these and didn't know what to do after
Thanks the the help and say I was getting a aftermarket steering wheel what size boss would I needThey hold the horn push on, once they are undone just get a screwdriver or something in the edge of the horn buton on the front and lever it out to expose the big nut underneath.
:yeahthat: except it's a 24mm nut.
One that fits the wheel you buy...and a Panda. Not many about really, I got lucky and got my 2 as they came up at non silly prices on the 'bay but fishing about quickly this looks like about it at the minute:
http://www.ebay.co.uk/itm/Fiat-Pand...11999647?fits=Model:Panda&hash=item417394b49f
6 hole Momo style fitment which is the most common. Just don't buy a Raid wheel which is very similar, but not quite the same. A lot of other bosses if you can find one are drilled for either. Mountney 'classic' wheels and Moto Lita are totally different, much larger centre holes.
