so, the TA (in the Panda) was designed (launched 2010?) for 5W-40 grade?
That being the case, regardless of subsequently revised software, the complex UniAir mechanical system (and other parts of the engine?) must be optimised for the originally specified thicker grade.
Which begs the question:
if your TA is a ‘keeper’, are the engine mechanicals going to give longer trouble-free service with the original thicker grade oil?
Comment
The question is important for owners who (I suspect) are likely more concerned about their investment in their own vehicle (costing many £££) than compliance with an EU standard…
You are missing the point I am trying to make, maybe not as concisely as I should... I recommend you read the leaflets that show how the system works in downloads if you havent done so as they are both enlightening and frightening!! Then you would see where Im am coming from. We all know its complex. It includes oil pressure, oil temerature and oil viscosity sensors / software. so these parameters are I think really critical. As the temperature and oil viscocity changes, these changes will not be in a straight line, the sofware takes both the readings from sensors and its map of the other parameters involved and adjusts both the extent of valve opening, and the valve timing to deliver optimum power. The base software map for different oils will be different. As the different oils respond differetnly the software must be set for each.
The engine will adjust its self to the oil sensor readings, but ay not be able to reach optimim of even correct operation if the oil, and the map of operating parameters dont match, so it may run OK most of the time, but fail at for example high of low temperatures.
I see your point about my statement on the design around the oil being spurious but its my understanding they worked with Petronas to fine tune the system for the Panda. Oils being now so specific to different engines, including the additives that go in after, and bearing in ind the fine tolerances and operating pressures needed to deal with this system I wouldnt muck with the oil at all. Like many things you can get away with stuff and use alternatives BUT beaing in mind we are talking small changes to affect the valve operation and massive impact if the valves dont operate as they need to, surely it is better to follow the specifications. I wouldnt really baulk at chucking most similar spec pils in any conventional engine, and put whatever I have in the Panda 1.2s as oils wil generally mix. EVen with the 1.2's I have had oil issues and the degree of startup chatter is very different from one to another. My punchline is really that the design and tolerances of the Uniair unit are more akin to recent formula one tech than nearly anything else and certainly everything else in the purchase price bracket and so I feel the oil spec if likely critical. If I had Euro 5 I wouldnt run the 0w30 unless I was certain the car had had a software update first. Maybe its my OCD but I think logic says dont stray at all with the oil spec when you know its not just providing lubrication but is a core factor in the valve timing. TIme will tell if I am right of if my TA fails later in life. I know one thing, while I love the engine and always marvel at its truly stunning performance charcteristics, particularly when towing half a ton up a steep hill, I am bloody terrified iof its going wrong and bankrupting me!!
Your point about using the thicker grade of oil is logical in inception but runs against the operation of the micrsopic computer controlled variable vale gear on the engine and I would still say stick with the very specific oil recommended. Not for the lubrication qualities as either would surely do that job, but definitely to keep the valves running exactly as they should. I
ought to start and to run better this way.
PS I actually hate Petronas and wont have it ever again even in the 1.2s. Ive had my justified rant on them before. (Unless I was sold a fake product). SO me running the TA on it is a teller.
