Technical Amber Engine check light on
Pbargh
Lancaster
I have a 2018 fiat ducato Mohome
The amber engine check warning light is on
If I take the vehicle on a short run but give the engine a bit of hard work ,up a steep hill say, the waring light goes off when restarting
I suspected lambda sensor at the cat , does anyone else have / had this problem?? Any answer will be great fully received
Thank you
There are a number of members that will help with use of Multiecuscan nearest to you i can find is in Blackpool
Use this template preferably for a 20 min run from cold
This will identify if the sensor is working as a minimum
Thank you for your replys. I will see if I can find a multiecuscan locally and take it from there. How do I find the member in Blackpool please
Click on
This takes you to the register entry . try a PM / Conversation with @Martec
