Technical (Almost) no boost Grande Punto tjet
SiriusNL
Netherlands
Hello everybody,
I have a Grande Punto 1.4 tjet with vl38 turbo, that is the only thing that is not stock its remapped at a fiat garage, been working fine for over three years.
My problem started with a misfire and a catalytic converter error message. Since then there is almost no boost from the turbo, also i dont hear the turbo or blowoff anymore. I have replaced the cat and the problem still persists. There are no error messages coming up anymore so that is good. Also cleaned the MAP sensor, but that dit not help either.
I have use MES to find the issue but i am not a car mechanic and need your help. Please take a look at this graph because to me the pressure compared to desire pressure is off quite a bit.
Thank you in advance.
Model
1.4 Tjet
2008
Mileage
205000
Have you checked to see if the turbo is all okay physically? These turbos love to crack their exhaust housings especially around the wastegate. If really bad will not make any boost as it will bleed it off constantly.
Really easy to check the hot side of the turbo. Just remove the cat.
Thanks for your reply, the mechanic checked the exhaust side of the turbo while he replaced the cat. He said it looked nice, also he test the wastegate, that was also working as it should.
Today I've checked the air intake side and i also didn't see anything off. Checked all the hoses going to turbo and the clamps, they are all fine.
It all happened when i drove out our street at it started to run on 3 cylinders with engine check light, then i went straight home. Check error numbers and it shows P0303 and P0420, because it happened on my birthday i didn't have time to check that day. The next day it started and run just fine only there is no turbo pressure anymore, error codes are gone. Went to mechanic, he discovered that exhaust was leaking, fixed the exhaust and replaced cat because of P0420. That didnt make any difference at all.
So here i am figuring it out myself, bought MES kit and found out i'm missing knowledge on what sensors to read and what is a wrong reading or not. So i just checked all the hoses and cleaned the MAP sensor. No result
The engine runs fine no hickups or anything, only that its slow as hell with accelerating and top speed now is like only 170km/h.
Added a new graph, maybe it helps
Since no one is willing to help yet, here is more info
Things that have been done so far:
- Replaced cat
- Replaced air filter
- Fixed leak exhaust
- Cleaned map sensor
- Replaced boost solenoid + checked all the hoses connected to it.
- Replaced intake hose going to turbo (leak)
- Checked all the hoses and clamps coming from and going to the inter-cooler
Additional info:
No power going uphill
On highway boost is 1-2psi max, taking over is almost impossible.
Turbo looks good on both sides
Hopefully somebody can help me because i have done all i could.
Have you double checked the exhaust housing to see if it is cracked? Whatever your problem is it is 100% mechanical issue. have you checked to see if the turbo actually moves? It could be jammed against the housing and not moving at all.
You can remove boost solenoid control completely by looping the system with the turbo then your wastegate will do boost control to rule that out.
I have checked the turbo at the intake side and it spins when i start the engine. I have had the manifold cracked once, it got welded, that could be a issue? Must be a big leak then, if i'm losing that much pressure. 6psi is max turbo pressure, its usually 14+psi
The turbos crack on the exhaust housing which if severe will mean very little boost and you will be constantly leaking boost past the wastegate.
My VL37 had a cracked housing and the used VL38 I replaced it with had a cracked housing too so extremely common. Replacement housings are not that expensive though and come with all the gaskets needed.
This was my old one. Cracked in two places.
Thank you for the info
This Wednesday the car is going to garage and the mechanic will take a closer look and do some pressure test(smoke). Also i checked for codes and it gave me; 'P0240 Turbocharger Boost Sensor B Circuit Range/Performance' no engine light.
Are there any other things the mechanic could take a look at?
The mechanic was sick so i had to do it myself.
Found a big crack in the exhaust housing like you said, replaced the housing. The only problem is that the car runs the same as before. Same boost levels. Like it didn't make a difference at all.
So what now?
New test run MES. On my boost meter it reaches 0.50 bar maximum.
Apparently i uploaded an older graph, here i have some new graphs. I notice that ''vacuum turbo valve'' stays off, that normal?
I've tried to test the solenoid actuator from within MES but i keep getting error 13, so that does not work.
Have you checked the little 4mm hoses that plug into the electronic boost controller and turbo actuator. They could be split and not giving you any boost as they control the vacuum for the boost actuator and the wastegate?
I have replaced all the vacuum hoses yesterday, Checked the placement twice with diagram, so that shouldn't be a problem.
Either the turbo ain't spinning quick enough, or there is a leak.
look at every part of the intake system looking for any sort of leak. Make sure the bypass valve is closing and more importantly sealing properly.
Run the car without the intake pipe and watch the turbo vanes, are the spinning properly?
Is this a variable geometry turbo? are the mechanical parts of the turbo, working as they should.
As stated the lack of boost is a purely mechanical issue. other than telling you the boost is low or not reaching the desired level, fault codes are unlikely to tell you much else.
It looks to me that the turbo is spinning properly.
Regarding the bypass valve, om not sure where and how to check that. Also notice that the intake pipe is little oily in the inside. It looks like that coming from the oil segregator as there is oil on the nozzle when i remove the hose.
I've removed the hose from the solenoid to the wastegate actuator and took it for a drive, no difference, same boost levels. Felt slower though
Tried testing the bypass valve by blowing on the hose connected to it, i can blow air through with some resistance. That shouldn't happen, it should be closed tight, right?
I think the bypass valve may be bad and sucking vacuum from there or it leaks boost through it. Any other way to test it?
Current vacuum pressure : -17 to -23 in/Hg @ idle
Current max boost pressure: 0.50 bar
