A very interesting point there about the multi stage airbags T, I always wondered what the exact differences and purposes of the stages were
Thanks to JR and to Jnoiles for the previous postings. And I would agree in full ernest on getting an airbag light fixed asap. I was trying to put a bit of 'balance' on the discussion.![]()
There are a number of youtubes on airbags and the way that they deploy. It would be advisable to sit well back from the steering wheel.
A few 'tasteful' ones...
A very interesting point there about the multi stage airbags T, I always wondered what the exact differences and purposes of the stages were![]()
Interesting. I'm guessing multistage is the reason we saw the yellow and purple wires going to the wheel airbag MEP.
Airbag ECU makes a calculation on speed, seats occupied, direction of crash and deploys the airbag(s) accordingly and also whether to partially or fully inflate airbag. Another note is the multipla, this has a massive (75 litre from memory) passenger airbag as it also has to protect the passenger sitting in the middle front seat.
Definitely. One of my coworkers had a head on accident a couple of years ago and went to press the horn (as you do when someone is about to hit you) and the airbog deployed and broke her arm.
Serves her right for having safety systems made from ceramic toilet sanitary ware.
Indeed, was the reason for the two plugs on the airbag unit. I always thought that perhaps Fiat had dropped the idea after the Stilo as that has multi stage mentioned on the front driver and passenger airbag, where as the 500 and other models don't from memory, but I believe that most probably are multi stage but just not mentioned any more. I know the mk3 Pandas are only single stage.
Friends of ours have switched from using an 10 year Astra to the 'good car' '08 Mazda 6 for the safety features for the school run (3 miles away). I can just imagine the safety rating given on the Astra.
It's not as bad as you might believe - we checked this before I sold my 52 plate Astra to my daughter. I was pleasantly surprised to discover it had a 4 star NCAP rating.
http://www.euroncap.com/tests/opel_vauxhall_astra_1999/44.aspx
That safety rating was pretty good for a '52 plate' car but noticed that the passenger faired better than the driver. There was no explanation given for the average rating on the driver.
Which interestingly is the same as an 08 Mazda 6.
http://www.euroncap.com/tests/mazda_6_2005/242.aspx
I suspect sometimes people assume a bigger car is safer perhaps??
Just checked the safety rating on the Mazda and it's poor for a '08 car getting only marginal ratings in the body area. My mate will be unhappy with that since it was very focused on the relatively low Co2 output.
Euro NCAP allowed Mazda to re-test with an improved front passenger restraint system. Spot-weld release at the base of the A-pillar and deformation of the sill indicated that the bodyshell was at the limit of its integrity and would have been incapable of withstanding a more severe impact. The car was penalised for this. Structures within the dashboard represented a potential hazard to the knees and femurs on the driver's side.
The 'up' side is that the 2 kids should be safer in the back and to drive it feels a lot safer than the 'old' Astra. The Safety rating doesn't seem to take account of those in the back so it not easy to see the differences.
This demonstrates that the 500 got a excellent rating when you compare it against others for those sitting in the front.
Jason thanks for your post and pics, I am still driving about with the airbag light on. I have ordered a workshop manual on cd and this weekend my dad and I are gonna try and fix the problem, we are hoping for a loose or dirty connection. While I am under the car I may check out the exhaust as it was noted as being rusty on its m.o.t, If im brave I may even attempt to change my brake pads and discs.............who needs a mechanic lol
I went car shopping at the weekend and couldnt find any I liked as much as my 500, flaws in all.
Im gonna see how this weekend goes before I contact Fiat, another dealer quoted me £500 to fix it with a new ECU costing aprox. £320 for anyone who is interested.
Have you solved the problem? I'm having the same issue on my FIAT 500.
