Technical 9 speed auto oil level
Andyshep
Loughborough
Dose anyone know the oil level for the zf 9 speed auto. I have a drive shaft oil leak, so am going to replace the seal. I’ve ordered the required dipstick to check the level. But need the info re level / temperature.
2022
Mileage
15000
Btw, If you need to add, what kind of oil do you plan to use? Now I've upgrade from manual to zf9 (for 2.3 2019-2020), gearbox is almost empty. We'll fill ~6L, after that with diagnose connected we will check the level and temperature. There are some steps to follow to check level. I have zf lifeguard fluid 9. It is also Mopar 8&9 speed ATF.
Found this one at the ram promaster forum, but don't know from where the measurements are taken
I’m hoping to order a litre from Fiat when I order the seal.
My local Fiat agent is having problems identifying the seal, hopefully they will have the correct part number tomorrow.
Thanks for your help
Maybe will help you to identify easier by yourself.
Of course it's a plastic stick with markings, in Romania is above 80 euro:)), but i don't have delivery. First of all i need to know if is the proper tool. Let's see the answer from @Andyshep. PN should be: 2000040963
