General 500c Rear 3rd Brake light
JonoM
Kent
New member hear so assume this has been posted in the past, so apologise in advance.
Can anyone recommend where to buy a rear 3rd break light for a 500C(conv).
Are there any after market, pattern part replacements?
Found a couple for sale at over £250 which is crazy when there are loads of these types of lights for £15, that as far as I can tell don't fit!
Jono
Hi and welcome to the forum.
It's been posted before that the sealed 3rd brake light unit on the 500C is crazy expensive, not available in the aftermarket and isn't designed to be repaired.
They often fail after about 5yrs or so; I wouldn't recommend getting a used part since it may well not work for very long.
There are some european sellers of purportedly OEM parts for less than £250, though they're still far from cheap. This, for example.
And I've just found this.
But some folks who are good at improvising repairs to the unrepairable have found workarounds; have a look at this post (and the thread it comes from)
Thanks for replying so quickly.
Just purchased the one you just found, fingers crossed its OK, worth the risk!
Jono
If you can remove the light I bet its possible to repair but you'll need to know what you're doing or simply modify with some different leds
That's what lummers did in the post I linked to.
But it doesn't look trivial.
Might be worth experimenting with the scrap old one once the OP's got this repaired, then he'll have a spare.
Hey, thanks for all the replies. So I ordered a new light, awaiting delivery, in the meantime I checked the voltage to the cable, only getting 0.18, 2nd issue when you test it it blows the fuse, big panic the first time as the whole dial & indicators go, put a new fuse in & thankfully dash came back, tried measuring again, same issue, only 0.18 volts & the fuse blows again, so must be shorting somewhere?
Been struggling with this issue too with warning lights going on the dash. Checked the middle raised LED brake and saw that 5 of the LED's are gone and have guessed that's the cause so ordered one off amazon. Hopefully will fix as really want to sell the car tbh. https://amzn.eu/d/7Q1fjKr
Part looks good, great price too!
Great video here of how to remove the light if you don't know already, took me hours to find one so hopefully save you some time!
