Technical 2013 Doblo 1.3 Diesel Not starting - loose lead / plug - where does it go?
Jimmals
Hi all
My Doblo (actually a Combo, shhh) is not starting. Ive found the culprit, a loose lead unplugged. Problem is, I cannot find the socket to put it in. Any ideas?
Looks like it only has three pins. Hanging down by starter motor and not much lead to go far.
I doubt that the cause of it not starting unless it's for something very important like the crank/cam sensor fuel pressure sensor ect
More the likely it's leftover wire in the room for something not on the car
Starter motor was replaced, and van broke down 10 miles later. There is seemingly an issue with earth now too as lights on dash are dim when key removed.
Did someone else replace the starter?
