Technical 2009 1.1 non starter
Ah ok
When i fit the locking tools the belts teeth and the cam sprocket teeth do t mesh they sit on top
Do i go clockwise 0.5 tooth or 1.5 toth
I can try both
Just pull it up and sit it on the teeth
It will be slack
You can see it's not tight in photo one
Mark it with some tip X or similar
Turn it back one tooth
Then put the locking tool back, the belt should be tight photo two
Wish I took a video, I didn't realise it was much harder to explain than it is to do it at the time
Having issues posting at the moment, internet very slow
Tried 6 times now and each time after turning it by hand twice the locking kit fits but still no attempt to fire up
So turning by hand the locking kit fits
And the cut out is at the top 1a
Do you have a compression tester ?
Have you hear the engine run before taking the head off?
did you check the basics, like do you have spark and are the injectors firing (and do you have fuel pressure).
Pics
Yeh i have a good spark and fuel and yeh i have a compression tester
I haven't heard it running but have had the head off and nothing unexpected in there
Pistons tops and bores all normal
But you would expect some sort of noise when trying to start it
Correct
Even with the head gasket gone, it should fire and idle on two cylinders
What's the rpm on a scantool showing
I guess it an active without a rev counter
Sounds very low
Is the battery flat, every one I test is normally around 300, which isn't going to help
Are the plugs getting wet
What's there gap
Do you have another panda ?
Ive not measured compression yet and there is a smell of petrol but will check the plugs
Let's get the compression done
If it's around 200psi at 300rpm we can put the timing to bed and move on
If you can turn the engine over and the locking tools fit and the cam notch is at the top, it's unlikely to be a problem
Before posting the fiat drawing of the cam tool in position I did do an image search and there was one site with the cam being timed 180ish degrees out
Are you sure the coil pack connectors from the ECU are on the right way round, at least on some cars they are long enough to plug in backwards
Rechecked the sparks, plugs , leads and fuel pressure and took out injector bar and all firing as the should
Yeh notch 1a is always up and mark on cam sprocket is towards the left where a timing mark use to on previous models
Mes says 170rpm when cranking
Going back to this
Normal its over 300
We are 50% down, probably means we have good compression
If you have another panda, swap the batteries or try jump leads
If the cars been running a tooth out, you will probably have to reset the adaptive memory using a scantool
You have got the valve cover back on and the cam sensor connected
