I found some info on early similar iveco engine.
5 degrees before tdc (cylinder 1 compression stroke) plus or minus 0.5 degree . The Bosch ve pump piston should read 1mm further out than the lowest measurable figure.
these numbers appear sensible but did not come from technical documents.
The injection sprocket has a hole (6mm?)
That in belt change position should align with another hole in the belt casing behind sprocket. A locking pin should be slid through sprocket hole into casing hole to lock the position while belt being changed.
Plus a number of different sized timing belt were used on the 8140 engine during the years-again Essential to use the correct belt
