A bit tricky then.
Hi Mike,i don't see any hose where it goes into the manifold......i think as far as i can see the turbo is bolted direct to the manifold. trouble is this is a Hymer motorhome and all that side of the engine is obscured by a bulkhead!
Hi JackHi everyone,
MrkT has an engine with a turbo waste gate (not a turbo actuator)
Turbos with waste gate; generate boost until the boost limit is reached, then the waste gate starts to open a small exhaust gas gate(valve) allowing some exhaust gas to bypass the exhaust turbine , this bypass stops the boost pressure building further .
A waste gate is a turbo de-activator if you like.
The waste gate is held shut-full boost- by a spring inside , when positive pressure from the small tube is sufficient to start compressing the spring the waste gate commences opening reducing boost.
If the waste gate actuator is faulty stuck closed it will over boost.
If spring is broken = no boost.
If waste gate in turbo is broken = no boost.
Cheers J
yes its a tag axle A class. (yes i know it is never going to be a Ferrari!)It's a hymer ! Does that mean A class ie huge?
yes there are two hoses coming from that (easily removed) that go across the front of the engine bay leading into/out of the inlet manifold.A bit tricky then.
Is there an intercooler at front of vehicle near the radiator that you can check hose near?
i had that apart last week....diaphragm is fine. i also tweaked it a quarter turn and the low pressure wheel at the bottom 1/2 turn. it improved it very slightly on the flat...but still no low down torque.Thinking sideways, there are two components in obtaining more power from an engine . Boost pressure, and the consequent ability to burn more fuel. If the boost pressure is present, then lack of power could be due to a faulty diapragm in the Bosch VE pump, boost pressure housing.
On my 2.8jtd, the intercooler hoses can be squeezed slightly by hand. If this is done while the engine is revved, it should be possible to feel the hose expand with the boost pressure.yes there are two hoses coming from that (easily removed) that go across the front of the engine bay leading into/out of the inlet manifold.
So maybe test for pressure there, same rules apply as before.yes there are two hoses coming from that (easily removed) that go across the front of the engine bay leading into/out of the inlet manifold.
i'll give that a try...thank you. (however not today as i'm waiting for a hub seal!)(and the drive shaft spins when engine is running without the hub on!)On my 2.8jtd, the intercooler hoses can be squeezed slightly by hand. If this is done while the engine is revved, it should be possible to feel the hose expand with the boost pressure.
i will do....thank you Mike.So maybe test for pressure there, same rules apply as before.
If boost is working when engine revs up it should be nearly impossible to hold it closed with your hand.
Make sure it is the pressure side.![]()
yes that should be a simple check (when i get the hub back together!)(bearing seal went) (as stated above the shaft spins violently with no hub attached!!)One hose should be connected to the boost side of turbo the other hose should connect to the inlet manifold.
Both hoses and intercooler are under pressure when turbo working.
If you are fairly happy you have turbo boost, then back to timing, both valve and injector as if either even a small amount out may be the answer.well today i invested in a smoke leak detector.........tested from the turbo inlet hose and looked everywhere and not one leak found!
(it was a little windy,so plan is to test again when its not windy....just in case)
if the turbo waste gate remains closed as it is,(the arm remains not extended) then in theory i should get boost.......and if the arm is extended then i get less boost correct? i cannot move this arm without getting pliers or a spanner on it,and being there is quite a bit of resistance (it wants to spring back) i think the spring pressure inside the waste gate is fine.
when my wife rev'd the engine twice in succession to see if this arm moved (it didn't) i could clearly hear the turbo spooling up/down (i was under the van near the turbo) so i think the turbo is probably ok.
i have always believed the injection timing is out on this engine.......(it has only done a genuine 52k miles from new by the way) i'm told the injection timing should be checked/reset after a belt change with a dti guage.(i bet it wasn't) she is quite smoky when cold,and it is distinctly fuel! once warm she runs clean. although when hot she is definitely more rattly. (like the timing is out)
i removed the cold start wax stat a long time ago........it failed twice! (i have a choke style cable to go on if needed but haven't found the need) (by the way when the wax stat was on it smoked a lot more!!) (mind you it was winter time and it always looks worse in the winter)
so if the timing is out would that explain the lack of power?
8140.47 was suggested by me in post #4. You should find confirmation on the VIN plate next to the heading "Motore".Hi Mike,thanks yet again......i think its the 8140.47 series. (i could be wrong) anyway its a 1996 2.5tdi. (or is it idtd?) i'm going to get an old school guy to look at the timing for me (he is supposed to be ringing me this morning.) W Pringle Ltd, based in Alnwick, Northumberland.
Am i right in thinking the timing should be 55 degrees on these?
Hi,you are of course correct. thank you. i'd forgotten you'd already mentioned it previously. (its an age thing!)8140.47 was suggested by me in post #4. You should find confirmation on the VIN plate next to the heading "Motore".
This is what I have for the 8140.47.Hi Mike,thanks yet again......i think its the 8140.47 series. (i could be wrong) anyway its a 1996 2.5tdi. (or is it idtd?) i'm going to get an old school guy to look at the timing for me (he is supposed to be ringing me this morning.) W Pringle Ltd, based in Alnwick, Northumberland.
