Technical 1.9td Ducato 10 2000yr speedo cable drive support
Hi guys!
Trying to locate a speedo drive support (for the dreaded 1.9TD box) - we suspect the plastic unit has suffered from excessive heat. Have just replaced the gearbox but
have a leak from the spe
edo drive. Have a new cable and seals, but need the actual support. Thought I'd found one from Coastal Motorhomes, but it's not quite right...
Model
Ducato 10 1.9TD
2000
To me it looks like someone has hacked at the black sealing o ring with a knife
You're absolutely right - I do have a new seal, and the condition of the old seal does suggest oil could easily have got past that - we can't figure out why anyone would have done that, but you just don't know the life they've had before you. If i can't locate a replacement support I'll juts try the replacement seal and fingers crossed!
What do you mean by replacement support?
Ah do you mean the compete item number 2 in your diagram, the light grey plastic part?
Yes, that's correct, the plastic part; number 2 in the diagram (would have been useful if I'd made that clear in my original post!)
